First time out for a play with the M3 and decided to have a quick spin around the local TV mast.
What happens when the mast comes between you and the drone? - loss of signal, drone goes into Return to Home mode and makes a bee-line back to the home point - and heads straight for the big steel tower that is now in it’s flight path.
Luckily I managed to get connected again before impact and shoot sideways to avoid a collision, probably with one of the guy ropes.
I would have presumed due to the size of the mast the M3 would have flown around it or just stopped, depending on your obstacle avoidance setting.
If the drone is currently recording a video it will continue recording. So I would have thought there would have been some sort of video of the incident.
Unless you were using the quick shot circle. But due to the video I would say you were flying manually as the circle is not round and the antenna is not in the middle.
With Drone Tweaks you would have been on a higher power setting so it would not have lost connection. I can highly recommend it.
I was flying manually trying to get used to the controls, I did cut the video short when it started to behave erratically and it automatically initiated a return to home.
