It is mate
if fires up ok minus the vista hence just gotta rebuild it now, thing is me ass is twitching a bit as the FC isn’t marked up hence gotta work from what I posted last time …
Just double and triple check everything before you put power up its arse
and use a smoke stopper or a power supply with current limit.
I so agree Steve, thats why I thought best to ship over a number of Items, I have a full Flight ScceX stack which comes in at around £100 now days hence may be worth spending a couple of ££ on it.
That said Im glad I dragged all my old stuff out as Iv discovered a skystar ECU what I thought was US is ok and a betafpv AIO which I didnt have the soldering skills for a couple of years ago iv now fixed ![]()
You bloody know it ![]()
What fc/esc have you got in your Firefly Nick?
Your right it does, Im assuming the RX4 is the Sbus ![]()
And BB in green the buzzer ?
Thats what it looks like to me. Rx 3 and Tx 3 will be for your OSD and will need setting to MSP on your ports tab
Just reading through the old post and your point here stands out, I might move the SBus to another pad well out of the way …
Yeah good point, nothing stopping you from moving the sbus to a completely different Rx ![]()
Yah its gone back together well no magic smoke so far, only problem I have is I cant remember how some of it screwed back together
I will have to check out a few pic’s on line, there fault I came across is with me vista, I think the guy who repaired them took the foam strip off that hold the VTX pin in place. But as always we improvise hence I used a gummy which seems to work well ![]()
Ok all built up just need to strap a pack to it and see what happens ![]()
Going to start building up the Beta85 next, after all thats what dinner times are for ![]()
I have 4 65mm tinywhoops and I decided it would be nice to have a 75mm one.
Rather than buy a new one I’ve converted a spare Mobula6.
I bought a Meteor75 frame, props and 4 450mAH BetaFPV batteries.
I had to do some small mods to the frame to get the motor connectors in, but it works.
I got an amazing 7 minutes of flight from a battery I took off the charger before it had completed it’s charge. That’s rather impressive.
Running Quicksliver with no mods from when it was a 65mm tinywhoop. It probably should be tuned.
I need a bigger box for it now
Thats very efficient, specially since you’re using a tri-blade prop. I get about 5 on my meteor running the biblade with betaflight.
Do you know if quicksilver is also adding elrs v3 compatibility with spi receivers?
Yes 100% I have one running with it.
Interesting…
Based on your experience, what is better with quicksilver in regards to betaflight?
Having a quick look at the features… Like this one…
“Torque boost is a highly experimental feature and can smoke brushless motors fast.”
Burn them motors ![]()
TBH it looks good for whoops with “easier” tuning. Will definitely be giving it a go when I have a play with the whoops again ![]()
More responsive. Better crash recovery. No ground effect. Auto turtle mode. Easy setup.
