An interesting concept, let’s see if it becomes reality.
How long before the ‘DJI Yanko - rumours, speculation and release date’ thread starts?
I predict worse wind resistance performance than a quad.
No doubt when it comes out it will be the #1 “Look at what I have” ???
Drone tech is going the way of novelty over utility of late.
Does the number of motors really affect overall power consumption that much ? For a given weight of drone you still need to generate the same thrust to keep it aloft
I believe larger propellers are more efficient (ref Mini 2 to Mini 3 Pro changes) but I’m not sure about quantity of props. I think I’ll stick with even numbers!
If it isn’t full frame with an hours flight time I’m out ;o)
…and in the <250g category, rock steady in force 6 winds, and unflappable signal strength.
Under £500 with £50 batteries
Homing in on it!
I see Spade Design’s renders show three clockwise propellers. So the whole thing will be spinning like a top. UFO sightings intensify!
Let’s hope a drone manufacturer sees this thread
It’s a similar effect as with a car’s engine RPM. Once it reaches a certain RPM the efficiency starts dropping off a cliff. It’s less sharp with electric motors but they do experience an efficiency loss with speed after a certain point.
So three small props are likely to be less efficient than 4 larger ones
Isn’t it likely to be noisy as can be? That’s a tiny duct to blow all that air through…
And DJI, spyware, the dangers of regular “software updates”, the rarity and expense of spare parts…
But if it has decent endurance and a decent camera, I could see a great future for it spotting artillery… (providing DJI approve the “cause” and allow it to fly there, of course)
I was thinking more along the lines of clay pigeon shooting. Pull!
Aa tri copter eh!.. Different I supose, but we already have the V-Copter Falcon which is a Bi Copter
One way to lose a bit more weight for the DJI Mini 4 eh!, remove two arms, two sets of props, two motors and 4 screws, then just add side sensors and they’ve cracked it.
