Earwig
4 December 2021 18:12
303
Somewhere local? Should I get my arse in gear and get the new Xings on my Nazgul?
Looked like a reasonable day this morning and I nearly ventured out, but I was waiting for my HobbyRC package and this afternoon’s been a stinker, so I’ve just vegetated in my hovel instead.
Tomorrow looks like it may be better.
Good job on getting your bird in the air.
BigDog
4 December 2021 18:17
304
For f**k sake I Cant believe it i sware I brought 6S motors
BigDog
4 December 2021 18:22
306
SirGunner:
They go to 4S max.
Can I change the pigtail on the FC to a XT30 then as I’m having to use a adapter???
Are your 4S batteries xt30?
BigDog
4 December 2021 18:31
308
They are and I can see where I went wrong yet another learning curve
You’ll be ok with 6s. Just throttle scale it.
In that case yes you could fit a new xt30 pigtail
Yeah where it says 2-6S that is dependent on which KV version you select. The lower KV option will be for 6S
Are they mapped correctly? They need to be.
BigDog
4 December 2021 18:42
312
notveryprettyboy:
mapped correctly
I’m not sure what that means ??
As in as in BF motor 1 motor 2 and so on if so then no …
Yeah. Is the esc back to front as I remember?
BigDog
4 December 2021 18:44
314
Yeah miss understood it …
Yes it is mate and looks like the FC is 180 degrees off too
@BigDog when you get 5 mins in front of betaflight, let us know. Its very simple to remap the motors and sort the fc orientation.
Earwig
4 December 2021 19:19
317
BigDog:
It is to you, Chellaston
Colour me intrigued. Is it the old farm buildings off Snelsmoor Lane?
BigDog
4 December 2021 19:29
318
It is mate you been before ???
BigDog
4 December 2021 19:31
319
notveryprettyboy:
remap the motors
Ok cheers does it take long ???
Go to the cli. Type resource and press enter.
Paste the results here.
BigDog
4 December 2021 19:34
322
Entering CLI Mode, type ‘exit’ to return, or ‘help’
Building AutoComplete Cache … Done!
resource
resource BEEPER 1 C13
resource MOTOR 1 C06
resource MOTOR 2 C07
resource MOTOR 3 B00
resource MOTOR 4 B01
resource MOTOR 5 B06
resource MOTOR 6 B08
resource MOTOR 7 B07
resource MOTOR 8 C09
resource PPM 1 A15
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 C10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 C12
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 C11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource I2C_SCL 2 B10
resource I2C_SDA 2 B11
resource LED 1 B02
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource CAMERA_CONTROL 1 B09
resource ADC_BATT 1 C01
resource ADC_RSSI 1 C03
resource ADC_CURR 1 C02
resource BARO_CS 1 C15
resource PINIO 1 C14
resource FLASH_CS 1 C08
resource OSD_CS 1 B12
resource GYRO_EXTI 1 C04
resource GYRO_CS 1 A04
