oh wait u have them on the unite the oppsoite way round ignore me. its been a long day got 2 bad gyros on 2 qauds
when i had my dji controller i would have had uart 3 as serial rx for the controller and uart 1 on msp thats for OSD. I have a vista also and is the same but i use crsf on that but same principal
Yah OSD is fine, could I dob into Rx2 as its next to the plug as Im not sure if I have any wire long enough to stretch across the board…
there shouldnt be a problem. im bad at english tonight
No I dont have anything soldered direct to the board …
i didnt explain that very well. u can use any other rx pad
Am I thinking right that they correspond to the Uarts in the port tab in betaflight ?? i.e. RX2 = UART2 ??
yes
can only use 1 uart per item/thing
Yeah just set Uart 2 as serial rx in your ports tab
Ok I may have a length of wire in my bit box that may be long enough.
Just snip it off 1 of the many plugs you get when you buy stuff… If that make sense ?
Just looking at it I may as well dob into RX5 as its on the same side …
I just found this as someone had the same issue and typed this into cli and solved the issue. sbus_baud_fast = ON. not sure if it will solve the issue but worth a try
Oky doky Ill give it a go later, off out for a bite to eat and dont think our lass will let me take it all with me to the pub
Cheers Buddy
You could be onto something there Ben. After having a Google it looks like there are 2 protocols you can choose between in the goggles. Sbus or Normal. Maybe it’s set to the wrong protocol for Sbus?
Were back to wizards and unicorns il check it out later mate
No one needs that. Team tits and dragons FTW.
Seriously, I’m not sure why I’m following this thread but I feel your pain. I’m sure you’ll get it sorted eventually. You’re getting the best help available.
set sbus_baud_fast = ON
@BigDog must use set
And remember to save
