Not sure if this is the best place for this as not strictly a modification.
I currently have one of these for my mini 2 which for the recreational stuff is absolutely fine.
https://www.amazon.co.uk/dp/B08X3Q8LF3?ref=ppx_pop_mob_ap_share
I would like to have a peli type case where I can put the mini 2 in with the wings unfolded.
Looking at getting one of these which if my calculations are correct should fit the mini 2 unfolded https://www.amazon.co.uk/dp/B07YXVRYFD/ref=cm_sw_r_cp_apa_glt_fabc_YS0CFXPJ20DYACS4AS58?_encoding=UTF8&psc=1
Any tips for the actual cutting out the inserts?
Failing that is there anyone that does a peli type case for the mini 2 where it can be stored unfolded?
