Hi all, do anyone have any advice on general care and maintenance the DJI mini 2.
Do I need to blow out the brushless rotors once in a while?
What another general care and maintenance would you recommend?
Thank you. I saw already and am storing my batteries in lipo bag separately.
In the memberâs area is a dedicated thread
Just saw this: DJI Mini 2 drone getting firmware update to address battery charging issue
The batteries can drain faster if theyâre left in the drone for a long time.
Dronemaker DJI says a firmware update is coming to fix a battery discharge issue in its DJI Mini 2 drone. According to TechRadar, the company says the update will âinitiate auto-discharge when batteries are in the drone or charging hub and have not been used recently.â Itâs a relatively minor issue that mainly affects the batteryâs longevity; lithium polymer batteries like the one in the DJI Mini 2 have a longer lifespan if they can discharge slowly when left at a full charge for a long period of time.
When storing batteries does one leave them with âpinsâ connected to the charger to drain to recommended levels electrically (hopefully72%) or turned around to drain naturally?
Sorry if already answered, but couldnât find any reference.
To the best of my knowledge the built in Battery Management System (BMS), inside the battery itself, controls the self discharge process.
In the first monthâs of the 2 there was a well publicised battery issue. If they were left in the drone or charging case (how DJI ship them), they didnât drain. That has been fixed and the batteries self-drain as per DJI spec.
Sorry if there is a newer thread but my search revealed this as most relevant.
I received a Mini 2 with the âFly Moreâ pack as a Christmas present last year. It doesnât get a huge amount of use but already two of the three batteries have failed with the symptom of two flashing lights in the charger pack.
DJI have replaced both pretty quickly under warranty but a 66% failure rate is pretty poor. My Hero 7 which suffers a similar amount of sporadic neglect still has all 3 batteries working perfectly.
Have you updated the batteries software? Search in here(above) and google as there is a well known problem with the batteries destroying themselves.
How regularly have you charged the batteries since Christmas last year?
Probably 10x. Almost the same as the Hero 7, the Panasonic Lumix and Olympus Tough that all live in my âphoto hobbyâ cupboard. Only the DJI has had premature terminal battery failure like this. The other cameras several years old and still going strong.
