indeed any everywhere else.
Was announced back in May.
Bought a Mavic 3 on the strength that I could use My RC controller with it. How could you not like it
Baffled ![]()
I see you can plug a usb c microphone into the data port on the bottom of the rc (next to the sd slot, not the charging port) and record audio when screen recording (from the ground not the drone just to be 100% clear!) now. Not sure if this worked all along or is something new that’s not been publicised in firmware updates for some reason.
They are pretty good.
Got well over 30 minutes the other day with 10% left
I have attempted to write a couple of reviews of both the Mini SE and Mini 3 Pro.
If anyone would like to have a look and maybe offer thoughts?
I bought mine from Very, tried to buy from Dronesdirect but they had no stock. Very delivered next day and have the fly more kit and extra batteries in stock ![]()
Fancy that ![]()
Drones Direct are an absolute nightmare @MarkRegan - you got lucky by not ordering from them.
Are you new to Very, did you take advantage of the 10% introductory offer ;o)
Won’t be long before they send you a 20% off anything (except apple gear)
The 10% off was very handy
I will await the 20% with great interest ![]()
Yeah, ordered, delivery date knocked back, so cancelled. I thought they would be OK as I bought a Laptop off their sister site a couple of years ago and everything went very smoothly, but it was in stock so, but hey ho ![]()
Has anyone connected the MM3 to the Dji assistant 2 yet? I have tried without success. Used versions 1.2.5 and 2.0.14. My mini 2 connects as OK… Wrong technique possibly? I need the Dji drivers for connection to DH. Thanks
I was reading on D H the other day I think , I say I think the assistant they recommend to download for some of the dji drones now is dji assistant for consumer drones , check it out if you haven’t already , sorry if you have already tried this ![]()
You may be on to it there as its not the version I downloaded /tried. Load it tomorrow and see ![]()
Hopefully that might do it
Let us know if it works .
I have always found that If i use Assistant v1.07 first, it puts the needed drivers into the system, I then install the latest version on top, and that gives me access then all all my DJI drones without further problem.
You can download V1.07 from HERE
