@DeanoG60 Not lie I do not have good hand and eye coordination or is it my slow brain response and fingers
Still flying mini 2 alot flew Mavic pro yesterday.
FPV got the hang of flying after months on the PC, can fly inside without banging walls and lights and wifeys ornaments getting a kick. I definitely enjoy the feeling of going outside and fortunately not had to solder anything yet as my skills of this is also as I’ve tried a few electrical stuff and balls them up for the bin
One thing that’s annoy’s me is I thought I be able to go a wee bit further then I can without losing signal and drone, I’ve got to use a tight signal circle but would like to go further out to have better run at obstacles as like I said I’m slow to react and a wider space be fantastic so yes I know a upgrade antenna
Whats the general consensus on the best colour for the furthest visibility on a wrap? Dark v light? Neon v camo. Are any colours better than others? My head says go black, but my heart says go crazy!
Thank you. I need to work on my search criteria as I often have a feeling there is already a discussion on things but when I do a search it brings back no results that seem right. Good job you’re here to point me I the right direction again. Thanks.
When it’s in the air, the darker the better ( except at night ) - note that all RAF trainers are now painted black - but when on the ground and you’re hunting through the undergrowth to find it a splash of dayglo really helps
Without a doubt I can see at 1451 ft easily now whenever the sun is shining on it, it took me a few hours to put it on but very satisfying afterwards, very good product but expensive at £40 , Brian
This wrap has been kicking about for almost exactly 2 years since it arrived … from Japan, since this camo wrap isn’t available from WrapGrade’s Amazon shop.
Almost the old girl’s 6th birthday. Thought it was time.
