Then too realise, not all the drivers had installed so you had to do it again, by then you’d gone Bankrupt
Plus my Wi-Fi is running slow with everything connected too it, plus next door has probably hacked in that’s my excuse anyway .
If you really need software to sort your photos try adobe bridge. That is actually free!
Otherwise my recommendation with folders is year/month/shoot
If you can be arsed, get into tagging your photos metadata with keywords. Makes them tons easier to find.
That came with my sub but not installed that yet but it’s sitting there with a couple of other bits.
I’ve kinda done that-ish thanks for your advice
I think if you right click on the DNG file, you can set a preference as to what program you want to open it with, PS should be in the list, select that, and then whenever you click a DNG. Photoshop should automatically open it
I worked that out, only 8 hrs later
My workflow is…
4 folders :
Raw Video
Raw Photo
Adjusted Video
Adjusted Photo
Within each these I have the following folder structure :
Year-Month-Day / Drone (be it Mini 2 Mini 3 pro or Air 2s in my case)
Plus a folder for final video render.
Probably not the best but helps me keep things sorted from each flight as I tend to get behind on editing.
Then I have a seperate Raspberry Pi Plex server serving the final videos and photos.
Select one of the images, option-I, I think it’s(get info from file menu),up pops a window and looks for ‘open this file with…’ and select the app you want to open this with and then select apply to all
Yes, I’m no where near videos yet, so it’s ……
DRONE FOLDER
PLACE YEAR MONTH DAY
EDIT
HDR
RAW
But the folder collapses or folders in one folder so too speak .
I see people mention those I have never looked in too it, what are they.
Don’t even think about it.
That’s what I thought, since I’ve been part of the forum, I always wondered when I see people mention them, just never looked it up I guess.
Fix your Mac first.
Don’t worry about the Raspberry Pi yet, they’re harder to find than a Ninja air fryer
NOooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
I’ve turned google off
That’s sorted
I take it there good then, what ever they are
Help me decide on this product: Best Price Square SBC, RASPBERRY PI 3 - MOD B, 1GB RAM RASPBERRYPI3-MODB-1GB By RASPBERRY-PI https://amzn.eu/d/i822wTv
Curiosity killed the cat don’t look nothing special, 1 GB etc etc
Yep…yep that’s the one I meant
