callum
12 March 2021 10:44
363
Still the same to be honest. Had to use the un-inverted pad to TX1. Couldn’t get anything to work using SBUS pad and inversion on in CLI.
It’s working but obviously can’t get any telemetry like I would have set up Fport or SBUS+SPort.
Forgot how confusing these bloody things can be.
Time for Crossfire upgrade me thinks
Njoro
12 March 2021 14:00
365
I need to at least get to fly this headache first before starting another one, but it’s in the back of my mind
Njoro
12 March 2021 14:02
366
callum:
I’m getting old, that’s my excuse…
Lots of info and Upgrade ideas for the Tinyhawk over in this thread:
Cheap Lock Down Quad
Njoro
12 March 2021 14:16
368
It’s all for my lockdown 3D printed Quad…
Just fitted a shark byte vtx to my 5" quad, but the camera is a little too small to fit.
Looking for 10mm m2 bolts
Sorry about the mud. But it adds character
I’ll take you up on that if I don’t find a solution tonight…
Here if you want, I could run them down to you
I’m good. I have an idea…
I’ve mounted the cam, but if you have a couple of 8-10mm m2 bolts when we meet this weekend, that’d be sweet
My toothpick had a motor issue. So tonight I replaced the motor.
The old motor had spat a wire at the bell:
As I’d got it on the bench I’ve also fitted some more aggressive props to try and increase the speed current fastest speed that I’ve achieved so far is 52mph.
Hopefully should get a bit more thrust from the higher pitch props I’ve just fitted
Successful hover test in my living room and Thunder Bug will live to fly another day
That motor can be repaired mate
I just wanna have a go of that pod racer Deans built
I’ve replaced the VTX on that as well so hopefully that’s fixed as well
For anybody interested this is what @notveryprettyboy is referring to:
… my Source One quad, for repair, following a little fire after ‘hard landing’
it got it’s power from an AIO FC which fortunately did not suffer any damage. Also motor windings all good, so could have been worse
