Hi folks, have a bought new fpv drone. The aircraft records to sd card for 3 minutes and 7 seconds every time then starts another recording. Recording to the goggles is fine and does not stop/start. The card is fine, there’s nothing in menu to limit record time. Card capacity in drone shows 28 minutes.Same card in goggles shows about 2 hours. Record quality is perfect, used several cards to test. I do remove the card for play back to edit, so not via the fly app. Anyone had similar experience?
Appreciate reply. Read threads but no definitive answer. Not a fault with the drone itself then? Card format or brand? Main concern resolve issue while still in warranty.
Yes. Been a bit slow on the up take. Sorry. Not a behaviour I have noticed on my old Mavic pro tho. May be the way I play back the recorded files on different machines. Thanks again.
