Did my first long waypoint mission with Litchi yesterday. As I was prepared for, I lost signal as the drone passed Gros Piton (mountain). It made a great video though, clip of below (will process the full res stuff when back from holiday):
However I used the “reverse” at mission end option expecting it to retrace its steps, back around the mountain. It turns out that isn’t what that does, so I believe it just hovered for a while, before initiating low battery return to home. I am amazed that I got the drone back, and am very impressed with the collision avoidance as it came straight back over the mountain - scary footage here:
Good to know collision avoidance works … most of the time.
Impressive footage! x10!
Don’t forget a low sun can trigger/confuse the collision avoidance. Had a case of that the other day when flying manually … not sure what would happen in a Litchi mission.
Airdata says 18m16s. Felt like longer, but the the wind can gust so that could explain.
The log from Litchi cuts out while the reception goes - if I can figure out how, I’ll upload the log from the drone when back. You can see where the signal is lost/recovered though:
Even though I know you get it back, that return video is a real butt-clencher!
Some really close calls in that … and, with only forward obstacle avoidance, all it would have needed was a branch from a tree to the side to be above the MP … and it would have been so different!
Amazing!
The other detail I failed to mention previously was it was starting to rain. Thankfully only lightly before I got it back - it can get heavy fast out there.
Now trying to figure out how to get the full flight log off the drone. Data Upload in Assistant isn’t managing to load anything.
Connected with Assitstant, you should be able to access the MP’s internal SD card and simply copy from there.
Should be able to upload to http://www.phantomhelp.com/LogViewer/Upload/ if Airdata won’t accept those files.
Hm, I cannot get this to work. In Assistant I go to Data Upload as instructed here (How to retrieve a V3 .DAT File from the AC) but instead of showing a list the spinner doesn’t go away. No USB drive is mounted either.
The storage card doesn’t get mounted either… I’ll try a different computer.
Problem A solved. “I don’t use android, I don’t need to install that driver” ← me being an idiot not realising that’s needed to talk to the drone.
Problem B - The data doesn’t appear to be there. The dates don’t seem to correspond to actual flights. I’ve pulled all the data off and had a look, but I don’t think it’s there. I saw a post suggesting the drone only stores so many logs and then stops once there’s no room left, and suggests deleting old logs - Keeping .DATs on the Mavic Pro accessible | DJI Mavic Drone Forum - though I’m hesitant to start messing with files on the drone directly, and in any case, that wouldn’t help getting at the log in question.
